Activity Forums VEGAS Pro how to zoom in a rush using a bigger rush size ?
  • how to zoom in a rush using a bigger rush size ?
    Posted by Lucas Pelus on April 22, 2016 at 7:40 pm
    Hey,
    I do not know the name of the thnig I want cause I’m not english speaker.
    I got some gopro rushs in 4k (from a friend) it’s drone vid.
    The drone was a bit to far so i was thinking adding this rush in a big project (with other rushs) in 1080p.
    Maybe I could add the 4k rush without being resized by vegas ?
    vegas could crop it in 1080 so it’s like a zoom ?
    Someone understand me ?
    How can we make that happen ?
    Thanks !
    John Rofrano replied 10 years, 4 months ago 3 Members · 8 Replies
  • 8 Replies
  • Aaron Star
    April 22, 2016 at 10:17 pm
    If your project settings are 1080p, when you drop the 4K footage on the timeline Vegas will auto scale the footage to 1080.
    Use the Pan Crop tool on the clip, or a separate track and use track motion, to crop in on the 4k footage and re-frame the to your taste. You can use the resolution numbers on the side to enter in exact frame size, in your case 1920×1080. You can also key frame the crop to stabilize, resize, or maintain the visual focus on a subject. Using the GRID overlay on the preview, you can set key frames every 10 frames or 1 sec intervals to maintain a rough lock on a subject.
  • John Rofrano
    April 23, 2016 at 1:22 pm
    [Aaron Star] “Use the Pan Crop tool on the clip, or a separate track and use track motion, to crop in on the 4k footage and re-frame the to your taste.”
    Be careful! You do not use Track Motion for zooming. Track Motion works at the project resolution so if you zoom your 4K footage with Track Motion, Vegas Pro will first convert the 4K frame to 1080 HD and then scale the 1080. This is NOT what you want.
    Always zoom using Pan/Crop. Pan/Crop will preserve the 4K media as it zooms in using the full resolution and then converting to 1080 HD only at the end, which is what you want to happen.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Lucas Pelus
    April 25, 2016 at 12:57 pm
    Thks all of you.
    I’ll check this and come back to you after 😉
  • Aaron Star
    April 25, 2016 at 6:40 pm
    Good to know. I guess I always used Track motion scaling down for PiP type things, and never noticed this before.
  • John Rofrano
    April 26, 2016 at 9:41 pm
    Yes, Track Motion is perfect for scaling down and making PIPs. You just don’t want to scale up with it.
    ~jr
  • Lucas Pelus
    May 1, 2016 at 3:30 pm
    Hey,
    I think it’s because of my little english but could send me a screen shot of the options you talkin about ?
    I m workin on a french version of vegas pro so i would like to be sure.
    Is this option in project parameter help or not ?
    Here is what I got on pan crop, I think it’s okay, so i Can zoom without loosing to much quality ?
  • Lucas Pelus
    May 1, 2016 at 3:32 pm
  • John Rofrano
    May 1, 2016 at 11:06 pm
    Under Positon: change Largeur to 1920 and Hauteur to 1080, and you will get a perfect HD 1920×1080 crop/zoom. This is how far you can zoom in without loosing any quality.
    ~jr
