Activity › Forums › Avid Media Composer › How to you export XDCAM .mov from DS
  • How to you export XDCAM .mov from DS
    Posted by Nik Mahoney on August 1, 2012 at 8:20 pm
    I have been asked to deliver footage from my DS system in the following format:
    Format: Quicktime .mov
    Codec: XDCAM 422 i60 50Mbps
    1920×1080
    29.97
    Is there any way to encode to this format in Windows? I’ve tried Calibrated, XDCAM browser, Sorenson, and Adobe’s CS5.5 programs, but the option just isn’t there like it is on an FCP machine. Is it even doable in Windows?
    Advice would be greatly appreciated.
    Nik
    Bouke Vahl replied 14 years, 2 months ago 3 Members · 3 Replies
  • Richard Sanchez
    August 2, 2012 at 6:02 pm
    The XDCAM quicktime codec is a part of the AppleHDVCodec.component that is installed when Final Cut Pro is installed. If you have access to system with both Avid and Final Cut installed, you can set up an export setting to export to an XDCAM quicktime. You could also export a same as source Quicktime out of the Avid and bring that file to compressor on a system that has Final Cut Pro in order to do that. That’s how I’ve done it in the past. I know Calibrated will decode XDCAM, but I don’t know if it will encode XDCAM.
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Nik Mahoney
    August 2, 2012 at 7:46 pm
    Calibrated won’t encode as far as I can tell. Unfortunately I need to do this on a Windows system so FCP isn’t an option.
    We have a FCP system in house that can do the transcode but we are trying to find a better, faster solution so that we can stay on the DS machine. But in the FCP vein, one thing we’re looking at is sending it to HDCAM and then recapturing in XDCAM on the FCP machine.
  • Bouke Vahl
    August 3, 2012 at 8:38 am
    Not sure about DS, but MC can export to XDcam.
    (copy the contents of an empty xdcam drive to the root of a drive to fool avid it’s an XDcam drive)
    Then you end up with an MXF.
    The XDcam tranfer tool (free from sony) can re-wrap this to a QT file.
    (you need to do this on mac)
    If you want to stay on Windows, you can use FFmpeg / FFmbc to re-wrap as well (and in fact it can encode it if needed)
    If DS can’t write to XDcam, FCP can, if the xdcam transfer tool is installed. No need for a tape roundtrip, just export a clip and import in FCP…
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
