Activity Forums Maxon Cinema 4D How to ‘wriggle’ in c4d?
  • How to ‘wriggle’ in c4d?
    Posted by Alan Lacey on November 20, 2012 at 4:42 pm
    Using R13. I’m trying to set up a lamp that has random light output. The sort of thing you’d use ‘the wriggler’ for in AfterEffects. Is there an equivalent in c4d or will I have to revert to xpresso?
    Thanks Alan
    FlashXDR,XDcamHD,XDcamEX,D9 etc
    FCS,AE,Combustion,LiquidSilver,Vegas,Edius,
    G5,MBP,Vista64,XP
    Alan Lacey replied 13 years, 9 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    November 21, 2012 at 12:36 am
    There’s not a direct equivalent to wiggler, but you can do it pretty easily with MoGraph:
    * create two lights — one at 100% and the other at 0% brightness;
    * drop them both into a cloner, set to one clone and blend mode;
    * assign a random effector with all parameters turned off but “modify clone” set to 100%. Set the random mode to noise or turbulence.
    Example: 4982_wigglerflicker.c4d.zip
  • Alan Lacey
    November 21, 2012 at 7:56 am
    Thanks very much Adam, I did half suspect Mograph would be able to do this but I’m very low on its learning curve.
    Alan
    G5,MBP,Vista64,XP
  • Sergio Juyak
    December 5, 2012 at 10:58 am
    Sorry for the late post. C4d does have something sorta similar called the vibrate tag.
  • Alan Lacey
    December 5, 2012 at 12:05 pm
    Thanks Sergio. I looked at this and it looks like it can be used but only with a bit of expresso converting either posn, scale or rotation to a value to control light intensity. Easier fpr me to get my head round tho’ than Mograph.
    Cheers Alan
    G5,MBP,Vista64,XP
