Activity Forums Adobe Premiere Pro How to work with large video files
  • How to work with large video files
    Posted by Ashley Davis on August 8, 2012 at 12:47 pm
    I have converted my old home video tapes from 30yr old cine tapes of more recent mini DV. I am left with roughly 20-30 videos but they have been converted to extremely large files, some up to 6GB. Because of this they won’t fit on to one single DVD which is what I would like to do.
    Can I maybe convert or transcribe them to a smaller size?
    Can you also tell me if I am going about this the best way. Basically I am putting each video into a new sequence on premiere, doing a bit of editing and adding some music and then once thats all done I will make a DVD menu with Encore and link them all together on the front page of the DVD menu. Is this the best way about this?
    Ashley Davis replied 14 years, 1 month ago 2 Members · 2 Replies
  • Steven L. gotz
    August 8, 2012 at 2:55 pm
    Assuming that the large files are DV AVI or some other common codec, when you edit the timeline, add your music, etc, then export to a format you can use in Encore (or dynamically link to Encore), then Encore will take care of properly coding your video to be used on a DVD. Which is generally much smaller a file than the original due to some massive compression.
    6GB of DV is about 30 minutes of video. That can be put on a DVD at the highest quality with no problem.
    Steven
    https://www.stevengotz.com
  • Ashley Davis
    August 9, 2012 at 10:01 am
    I have just got a secondary monitor, identical to my existing one and I want to extend premiere CS6 onto both displays.. how can I do this?
    I am aware you can make the playback monitor play from the secondary one but I really want to extend the entire workspace over both if possible so the timeline will go from one to the other.. is this possible?
