Activity Forums Adobe After Effects How to work out what assets After Effects is using?
  • How to work out what assets After Effects is using?
    Posted by Olly Lawer on June 24, 2014 at 8:14 am
    We’ve got a bit of a messy comp. Lots of experimenting and lots of folders/assets. The trouble is, now the project is finished the client wants the raw files/AE so they can export themselves.
    Although not necessary, I’d like to ditch everything the final comp isn’t using. This way, they’ll have a nice, neat and tidy AE file with only the things they need to worry about.
    We’ve got a rather rudimentary system so far, only copying and relinking assets within the timeline, then deleting everything else, but if you see the comp, you’d understand the need for a ‘function’ to just tell us what’s being actively used and what isn’t.
    I know in FCPX there is a way to do this easily – telling us what footage is being used and what isn’t. However, I cannot see a way in AE of doing this?
    Kind regards,
    Olly Lawer
    Walter Soyka replied 12 years, 3 months ago 3 Members · 2 Replies
  • Bhavesh Jadav
    June 24, 2014 at 10:09 am
    Hi Olly,
    You can do that by going to file menu>Remove Unused footage.
  • Walter Soyka
    June 24, 2014 at 12:27 pm
    Bhavesh is right.
    A couple other related tips:
    You can select a comp (or really any selection in the project panel), then use File > Dependencies > Reduce project… and it will remove everything not required for the selection. This can be very helpful when you have many comps in the same Ae project and want to reduce it down to just one or two.
    You can also filter the project panel. In the project panel search box, type “used” or “unused” to see what elements are used and unused in the project, respectively.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
