Activity › Forums › Adobe Premiere Pro › How to work on a portion of a larger Premiere Pro CS6 project on another computer?
Posted by Lucian Perkins on December 19, 2012 at 5:37 pmI have a very large Adobe Premiere Pro CS6 project that I’m working on at home. While I’m gone for the holidays, I’d like to take a small portion of that project (whole project is 6tb and too large to take, so I’ll take 1tb of it), work on it, and then return and reintergrate it into the larger project. Is there a way to do that?
LucianLucian Perkins replied 13 years, 8 months ago 2 Members · 4 Replies -
Walter Soyka
December 19, 2012 at 8:52 pmHow do you have the project organized? Can you split it cleanly into 2 projects (one for the 1 TB you need, the other for the 5 TB you don’t), or is there a lot of overlap?
What kind of footage are you working with, and how is it arranged on disk?
What is the storage like on your system now, and what will it be like on your other system?
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Lucian Perkins
December 19, 2012 at 9:14 pmThanks Walter for replying:
One project broken into many sequences within the project. On my RAID I have SLR footage in numbered folders that hold from 1-2 Terabytes each, so I can keep them backed up. The sequence that I’m working on now and want to take to work on is in one folder.
I could pull the footage I’m working on, because it is in one folder. I’m wondering if I could just pull that footage, put in on the HD that I’m taking with me and then link it. But my project will then have all this unlinked footage on my laptop. PP will have a lot of footage it won’t be able to find. I was considering this. Take the footage I’m working on and keep it in its folder and hope PP will link with it and not worry about finding the other footage missing.
I’m working with 5D footage in folders with its sound. Each folder contains about 2tb of material
I have a 12 TB Raid system and I’d like to take my footage on a 1Tb Hard Drive.Hmm, maybe this will be to difficult to do?
Best, Lucian
Walter Soyka
December 19, 2012 at 11:08 pm[Lucian Perkins] “I could pull the footage I’m working on, because it is in one folder. I’m wondering if I could just pull that footage, put in on the HD that I’m taking with me and then link it. But my project will then have all this unlinked footage on my laptop. PP will have a lot of footage it won’t be able to find. I was considering this. Take the footage I’m working on and keep it in its folder and hope PP will link with it and not worry about finding the other footage missing.”
As long as you preserve the directory structure from one disk to the other, once you link one file, the rest should re-link.
If you can use the same drive letter (PC) or volume name (Mac) and directory structure for your 1 TB drive on your laptop as you have for your 12 TB RAID on your desktop, you should be able to avoid relinking altogether. If you go this route, you never have to permanently offline the missing files. When Premiere complains about offline media, you should be able to Skip All (instead of Offline All). It will ask you every time you open your project, but when you move the project back to your full system (again, with identical drive letters/volumes and directory structures) it should just see them, no re-linking required.
Walter Soyka
Lucian Perkins
December 19, 2012 at 11:13 pmThat’s what I’ll try by renaming the file structures to match. Many thanks!!!!
