Activity Forums DaVinci Resolve how to work Da Vinci Resolve Lite in Grassvalley Edius 5.5 or higher version of Edius ?
  • how to work Da Vinci Resolve Lite in Grassvalley Edius 5.5 or higher version of Edius ?
    Posted by Pabitra Kansakar on July 7, 2013 at 6:45 am
    Hi all
    I just downloaded the DaVinci Resolve Lite.
    I want to use this with Grassvalley Edius 5.5 or higher version but don’t know how to install it in to Edius as plug-ins.
    If I install as standalone software then how can I take edited timeline clips in Edius to Da Vinci Resolve Lite , do color correction there and then again take it back to Edius timeline ?
    A complete workflow or tutorial is highly appreciated. Thanks.
    Regards
    Pabitra Kasaa
    Prathvish Hegde replied 13 years, 1 month ago 2 Members · 3 Replies
  • Prathvish Hegde
    July 10, 2013 at 12:13 pm
    Davinci Resolve is not a plugin it is a standalone colorgrading software.
    export xml(?) or edl from edius and re-assemble in resolve grade and export with source filename. if you want to go back to edius and you can relink to the exported graded shots .
    prathvish hegde
    colorist
    (DaVinci Resolve and 2Kplus)
    https://www.youtube.com/playlist?list=PLRPJQ3fIEoojI3JMa4rHKb9gqq8VeIZ81
  • Pabitra Kansakar
    July 10, 2013 at 12:43 pm
    hi Prathvish
    thanks for the reply . does the resolve lite suport the canopus HQ files ? it will be more helpful if you could post the detail procedure for both SD/DV and HD timeline from edius 5.5 to resolve lite and vice versa. Thanks.
    Regards
    Pabitra kasaa
  • Prathvish Hegde
    July 12, 2013 at 11:22 am
    hi prabita,
    i think you should go through the manual to see what files are supported on resolve and accordingly export from Edius.
    i dont think canapous hq is supported on resolve.
    import the aaf exported from edius in resolve and link the files to the source files (the actual files you used for editing in edius)if they are compatable or if it is not compatable then export the files with the source timecode and filename in a format that can be read in resolve(dpx,prores,mxf etc) and relink the aaf exported from edius with the converted footage .
    prathvish hegde
    colorist
