Activity Forums Audio how to wire a PPM …
  • how to wire a PPM …
    Posted by Matthias Halibrand on April 26, 2008 at 10:37 am
    Hi guys,
    I would like to install a PeakProgramMeter (PPM 1206 manufactured by RTW) which I happend to still have to my newly installed Kona3-Breakout-Box. This has two cinch-connectors for stereo out.
    The PPM has only 5-pole DIN-connectors, which are differently labelled, so which one to use, and what pole goes where?
    They are labelled as follows:
    1.: 175 mV – 30V/> 47K
    2.: 1,55 V/> 47 K
    3.: 155 mV/> 42 K
    The first one has a PTC-resistor (I’m not sure if this is the right translation) on each side, which can be adjusted.
    So, which one is the right one for the analog line-out of the Kona3-breakout-box?
    What pole-number inside the DIN-plug do I have to solder to what pole of the cinch-plugs?
    If I want to use the same out for monitoring, too, how would I do that, since the PPM doesn’t seem to have an out.
    Thanks a million for your help,
    MatzeHali
    Matthias Halibrand replied 18 years, 4 months ago 1 Member · 1 Reply
  • Matthias Halibrand
    April 30, 2008 at 10:26 am
    Is really noone of the Audio-Pros able to answer that question?
    Come on guys!
    Thanks anyways,
    MatzeHali
