Activity › Forums › Adobe After Effects › How to viwe Andrew Kramers tutorials
Posted by Joakim Dalfors on July 22, 2006 at 7:11 pmHi!
I hope I havenMajorasshole replied 20 years, 1 month ago 4 Members · 5 Replies -
Erik Pontius
July 22, 2006 at 7:31 pmHis, as well as others, are encoded in flash. You’ll need to download the latest flash player to view. Also IE has some built in “security” measures to prevent “unwanted” programs from installing themselves without you knowing it (spyware, etc..)causing this “click to activate” message at the top of the browser window to warn you. Clicking on the bar should give you the option to “allow” it to install.
Macromedia was recently bought by Adobe, so you can find the latest flash plugins on Adobe’s website:
https://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash&promoid=BIOWErik
Erik Pontius
July 22, 2006 at 7:33 pmThis article from the Flash FAQ can probably help explain:
https://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_19166 -
Joakim Dalfors
July 23, 2006 at 5:31 amThanks for the info and especially for the link to download Flash.
Below all the tutorials there has been a link do a download, which as I mentioned above, I installed but still no success.The download you pointed to on the other hand worked perfectly and now I can enjoy all the tutorials.
Many thanks
Joakim
