Activity Forums Blackmagic Design How to view full screen SD on a HD monitor via MBX box
  • How to view full screen SD on a HD monitor via MBX box
    Posted by Robin on October 23, 2006 at 1:08 pm
    Hello
    I’m using a Apple cinema display via a MBX with FCP 5.1
    For the first time in ages I’m trying to grade an SD project, and because of the resolution the image is tiny.
    Can I change settings somewhere so that I can view the output full screen?
    8-bit uncompressed timeline
    Thanks.
    Robin replied 19 years, 10 months ago 2 Members · 2 Replies
  • Andrew Mcleod
    October 24, 2006 at 5:24 am
    Hi
    System Preferences > Decklink > Output > DVI settings – You will then open a control panel for the DVI interface. Here you can adjust and increase the SD output to fill the entire screen.
    Best
    Andrew McLeod
    pcsupport@blackmagic-design.com
  • Robin
    October 31, 2006 at 12:14 pm
    Great! Thanks – all working well.
