Activity Forums Adobe After Effects How to utilize stylish wipe transition with alpha?
  • How to utilize stylish wipe transition with alpha?
    Posted by Cassidy Clawson on May 11, 2012 at 11:34 pm
    Hello all,
    I would like to use this transition to wipe between two clips.
    https://www.pond5.com/stock-footage/10877277/transition.html
    It has an alpha channel, and as you can kinda see, the burn is never totally opaque. I would like to try to use this to wipe between two clips… how would you guys do it?
    My first approach was to simple fade the first clip to black as the transition wipes, then, in premiere, use a carefully timed additive dissolve to fade to the next clip. The results are decent I guess. I think it can be better.
    What would YOU do?
    https://youtu.be/Y9BJTtCoauE
    John Cuevas replied 14 years, 4 months ago 2 Members · 1 Reply
  • John Cuevas
    May 12, 2012 at 1:39 am
    Try a dissolve the same length(or a just a few frames shorter) as the wipe and set the wipe to add.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
