Activity Forums VEGAS Pro How to use Vegas plug-in control over third party software
  • How to use Vegas plug-in control over third party software
    Posted by Derek Antos on February 20, 2010 at 2:17 am
    Hard to explain what I mean.
    For example I have Magic Bullet Looks and it uses this Looks builder when I select to use the FX with the plug-in. When I used Vista before I upgraded to Windows 7, I didn’t have to use the Looks builder but instead all of the FX were individually sitting in Vegas and I could use Vegas control which was much easier.
    Any idea on how I can make it so each effect is back into Vegas and I don’t have to use the Looks builder?
    Theo Van laar replied 16 years, 6 months ago 3 Members · 3 Replies
  • John Rofrano
    February 20, 2010 at 3:37 pm
    Are you using the 64-bit version of Vegas Pro? Magic Bullet doesn’t support 64-bit Vegas. Otherwise everything works the same in Windows 7 as Windows Vista for the 32-bit versions.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Derek Antos
    February 20, 2010 at 7:38 pm
    I actually just found I had Magic Bullet Quick Looks before I got Windows 7 and somehow it upgraded to regular looks. I liked quick looks better because I could go through the whole timeline and look at the effects but with regular looks I can only look at a single still frame then accept and move around on the timeline later.
  • Theo Van laar
    February 20, 2010 at 10:21 pm
    I thought that quick looks are just presets. With the full MB Looks, you can make it exactly the way you want. And much faster and easier then when you have to obtain the same result directly in Vegas. So soon you will enjoy the fact that you ‘have switched’to the full version of Looks.
    Theo
