Activity Forums Apple Final Cut Pro Legacy How to use the new Prores versions ?
  • How to use the new Prores versions ?
    Posted by Jakob Mortensen on October 29, 2010 at 8:13 am
    Hey
    I just upgraded to FCP 7, BUT on mediocre hardware (macbook intel core2 duo 2.4, 4gb ram). I am looking for the most effecient way to work with AVCHD files from a consumer cam (panasonic G2, 720p avchd).
    For that reason I am interested in the Prores LT and Proxy, but being a bit new to this game I am wondering if they are only for editing or used also for output.
    Wouldnt the prores LT or proxy be able to keep all the quality of a consumer file, or is anything gained by transfering to normal 422 ? If you use the proxy or LT how do you do it. Is it a matter of setting up the log and transfer function to use those, and then you stick to those in the conplete workflow ?
    How someone can help.
    Best wishes
    Jakob
    Nick Meyers replied 15 years, 10 months ago 7 Members · 8 Replies
  • 8 Replies
  • Zak Ray
    October 29, 2010 at 1:56 pm
    Use LT. Proxy is a little low even for consumer AVCHD.
    In Log and Transfer, set the AVCHD preference to LT. Then say Yes when it asks you to set Sequence Settings to the clip.
  • Paul Jay
    October 29, 2010 at 2:59 pm
    With an external harddrive you could edit most HD formats on this machine. Far from mediocre.
    Indeed. don’t use Proxy. The name says it. It’s a proxy (offline) format.
    Use LT or normal ProRes 422
  • Jakob Mortensen
    October 29, 2010 at 6:52 pm
    Ok great thx to you both I will try the LT version out.
    Best wishes
    Jakob
  • Shonnan Wibrow
    October 29, 2010 at 7:01 pm
    I’m also upgrading to FCP 7 wanting to use ProRes for a sequence of clips shoot on a goPo HD at 1280×720 pixels (16:9), 60 fps, 15 Mbit/s data rate, would Proxy setting be good enough, or LT for safe measures?
    thanks
  • Zak Ray
    October 29, 2010 at 7:18 pm
    Well, run a test and see the results for yourself. Personally, I’d still stick with LT. But if you don’t see a difference (on a decent monitor, of course) then go for it.
  • Chad Tingle
    October 29, 2010 at 8:44 pm
    [shonnan wibrow] “wanting to use ProRes for a sequence of clips shoot on a goPo HD at 1280×720”
    Use Mpeg stream clip and convert it to pro res and play with the quality setting in stream clip to see if you can find a good marriage between quality and file size.
    Chad Tingle
    Producer/Editor
  • Andrew Evans
    October 30, 2010 at 7:58 am
    Proxy is an offline format. its just a reference to the original media. when I work with gopro footage i bring it into compressor and transcode it to prores and then take that file to fcp.
  • Nick Meyers
    October 30, 2010 at 1:22 pm
    “its just a reference to the original media”
    that indeed is one meaning of “Rroxy”,
    but Prores Proxy is self contained media, not a reference.
    it’s “proxy” in that it’s really too low in quality to use for final products.
    nick
