Activity Forums Creative Community Conversations How to use the Event library correctly
  • How to use the Event library correctly
    Posted by Robin Lewis on July 17, 2011 at 5:56 pm
    I could do with some advise, I find it strange that when you have a new project the Event library doesn’t re-set for that project, meaning every project has all of you media in this is frustrating as i work with projects that require large amounts of media. I know it keeps it in its own events which is good but my main concern is the use of Key words there just seems to be too many!
    For example I just imported a new collection of media for a new project went to log it but my keyword editor is full of old logging words from the last project! Can i change these words with out changing the logging on the old projects?
    Jerry Hofmann replied 15 years, 1 month ago 2 Members · 3 Replies
  • Jerry Hofmann
    July 17, 2011 at 6:49 pm
    Think of the new browser as having the same basic things as FCP 7… i.e., an FCP 7 project has become an Event, and Bins have become keywords… you can have as many or as few keywords as you choose.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Robin Lewis
    July 17, 2011 at 7:02 pm
    So if in an old Event I have used Keyword space 1 as “City wide” in event two can i delete that description and replace it with a new one with out it changing the “city wide” meta data I had laid in my old event??
    Also i wasn’t so impressed with the auto analysing and smart collections, it took 3 hours to scan all my media and got pretty much none of it right for instance almost all of the shots just have one person in it and it found two shots for this smart collection! the shot size’s it got totally wrong dont think ill use this function again.
  • Jerry Hofmann
    July 17, 2011 at 7:54 pm
    As far as I know, keywords are associated with the Event they were created in, so changing one shouldn’t delete the keyword collection from a different event.
    Jerry
    Current DVD:
