Activity › Forums › Adobe After Effects › How to use the cineon converter?
Posted by Noizzz on January 16, 2007 at 12:27 pmHi,
I
Noizzz replied 19 years, 7 months ago 2 Members · 2 Replies -
Peter O’connell
January 17, 2007 at 3:51 amWhether you need the cineon converter or not depends on what you are doing to your footage. For output dpx and cin are identical except that the dpx files have info in the header (timecode etc) usually exporting as cin is fine.
What do you need to do to your footage?
Good luck
PetePS: Stu Maschwitz has written alot about cineon workflow in AE. Look around on the net for some of his articles.
