Activity Forums Adobe After Effects Expressions How to use “sourceRectAtTime” expression with characters below the font baseline
  • How to use “sourceRectAtTime” expression with characters below the font baseline
    Posted by Henry Gaunt on July 25, 2017 at 8:37 am
    Hello cows –
    I’m using this expression on a shape layers ‘rectangle path 1’
    s=thisComp.layer("THIRETEEN");
    padding = 60;
    x=s.sourceRectAtTime(time-s.inPoint,true).width;
    y=s.sourceRectAtTime(time-s.inPoint,true).height;
    content("Rectangle 1").content("Rectangle Path 1").size/2;
    [x+padding,y+padding]
    It works perfectly.
    However, when my text layer has a ‘,’ (comma) in it, the whole box increases in size all the way around. Almost like a 10px stroke is being added.
    It affects any character that sits below the text base line. e.g.; q, y, p – I’ve solved it by using upper case, but the comma is still persistent.
    Is there a reason for this?
    Thank you for any help.
    Henry Gaunt replied 9 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
