Activity Forums Adobe Premiere Pro How to use presets correctly
  • How to use presets correctly
    Posted by Vipati Hitesh on October 16, 2013 at 5:50 pm
    Hello All,
    I have created some presets in premiere pro & want to use them correctly.
    I made some changes to the Scale & Rotation property of a video & save them as preset as I want to use them frequently. Now my problem is that if I apply that preset to any video it creates key frames starting from 3rd second (This is because when I made that preset I started it from 3rd second). But I want to use that preset at different time in different videos. For example, I want to use that preset at 15 second in “A” video & at 50 second in “B” Video. Every time I have to cut key frames from 3rd second to another.
    In simple words, I want to start (or paste) that key frames from current time indicator. If I apply my preset when current time indicator is on 30 second then key frame should be start from 30 second.
    I hope you will be able to understand what I want to do.
    Thanks & Regards,
    Vipati
    Vipati Hitesh replied 12 years, 10 months ago 2 Members · 2 Replies
  • Gabriel Sanchez
    October 16, 2013 at 7:18 pm
    Not possible.
    But there is something you could do:
    When setting the preset, allocate first keyframe in the first frame of the clip, then save the preset with “Link to in point” option.
    If you want to start (or paste) that keyframes from current time indicator, cut the clip in this point and apply the preset to the cut.
    Regards
  • Vipati Hitesh
    October 17, 2013 at 2:12 am
    Hello Gabriel Sanchez,
    Thanks for your reply. Is there any plugin which can do this task?
    Can anyone who knows about Premiere Pro SDK (Standard Development Kit)develop this kind of plugin?? If it is possible to develop this kind of plugin please help me, it can save my lots of time.
    Thanks & Regards,
    Vipati
