Activity › Forums › Adobe After Effects Expressions › How to use length in if statement
  • How to use length in if statement
    Posted by Tom Ono on May 13, 2020 at 7:00 am
    Expression tells “undefined variable used in expression”
    If there is not if statement,it works.
    I used text source so that I make sure if length(s) was recognized.
    Length(s) was recognised.
    I want to know what is wrong. thanks.
    target=thisComp.layer("circle");
    s = sub(target.transform.position,transform.position);
    if(length(s)<=100){
    lookAt(target.transform.position,transform.position);
    Tom Ono replied 6 years, 4 months ago 3 Members · 3 Replies
  • Scott Mcgee
    May 13, 2020 at 8:01 am
    I’m not sure what you are trying to do with the lookAt, as I’ve never used it before. But it works fine in text source.
    target=thisComp.layer(“circle”);
    if(length(s)>=100){
  • Andrei Popa
    May 13, 2020 at 8:56 am
    I think you also need to give it a value if the distance is greater.
    target=thisComp.layer("Circle");
    if(length(s) <= 100){
    }else{
    value
    Andrei
    My Envato portfolio.
  • Tom Ono
    May 14, 2020 at 6:06 am
    It works.
    Thank you for giving me good advice.
