Activity Forums Adobe After Effects Expressions How to use Javascript text decimal only retains the single digit?
  • How to use Javascript text decimal only retains the single digit?
    Posted by Ming Hsu on January 5, 2023 at 11:59 am
    I wrote a number addition,
    As long as there are more than ten digits, the following single digits are reserved.
    Y =
    thisComp.layer(“QiuCards_ 4”).essentialProperty(“B_Dot_”)+
    thisComp.layer(“QiuCards_ 4”).essentialProperty(“TopDot_”)+
    thisComp.layer(“QiuCards_ 5”).essentialProperty(“B_Dot_”)+
    thisComp.layer(“QiuCards_ 5”).essentialProperty(“TopDot_”)
    if (Y > 10){
    value = Y – 10;
    }else if(Y < 10){
    value = Y;
    When i number addition greater than 20.
    it’s doesn’t work,
    my text will be come decimal number.
    Ming Hsu replied 3 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 5, 2023 at 5:30 pm
    It’s hard to picture what you’re describing. Can you maybe post some screenshots?
  • Ming Hsu
    January 6, 2023 at 2:55 am
    Thank u Dan.
    i solved it!!
    In the end i put this script.
    (“0” + Y ).slice(-1);
    Here’s a little game where I’m making a template.
    The sum of the points of the two cards exceeds 10.
    Only look at single digit numbers.The maximum is 9 and the minimum is 0.
