Activity Forums Adobe After Effects Expressions How to use expressions to invert position properties?
  • How to use expressions to invert position properties?
    Posted by Eduardo Asta on May 9, 2022 at 11:33 am
    I’m building a rig do controle a bunch of layers. A typcal shape layer must move from A to B if its index holds an odd number. But if the index is even, it must go from B to C. It means, it must go in reverse direction.
    The following expressions has worked for the majority of the layers:
    var a;
    inverter = thisComp.layer(index+5).transform.xPosition;
    if (inverter> 0){a = 1} else {a = -1};
    Offset + value*a
    But for some layers the expression is not working at all (see image bellow). Does anyone know how to solve it?
    My best,
    Eduardo Asta replied 4 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
