Activity › Forums › Blackmagic Design › How to use DeckLink Video Capture directShow Filter?
  • How to use DeckLink Video Capture directShow Filter?
    Posted by Polihaev Viktor on May 27, 2010 at 3:24 pm
    Good day.
    Short version of my question is: Where can I find examples of code for “DeckLink Video Capture Filter”?
    And long one:
    I build simple application in C# what use directShow.
    At first I created prototype of my “graph” in GraphEdit application and it looks Ok and works:). After this I try to do the same in code, but the code not works for the filter:
    type = Type.GetTypeFromCLSID(new Guid(“44A8B5C7-13B6-4211-BD40-35B629D9E6DF”));
    IBaseFilter captureDevice = (DirectShowLib.IBaseFilter)Activator.CreateInstance(type);
    graphBuilder.AddFilter(captureDevice, “captureDevice”);
    IPin sourceOut = null;
    captureDevice.FindPin(“Capture”, out sourceOut);
    // the pin is always null 🙁
    I know, the can not work correctly (the capture card should be initialised and recieve parameters like a videoformat etc.), but in “GraphEdit” it works.
    In “DeckLink DirectShow Documentation” defined what interfaces has the filter, but not “how to create the Object and set parameters”
    Also I tried to do it using DeckLink SDK. In this case, it easy to control the card, but I can’t have access to directShow interfaces(like IBaseFilter) and to add the com-object to my graph.
    So, if you have example or can explain “What i did wrong?” – I will happy.
    Ian Clark replied 15 years, 11 months ago 3 Members · 2 Replies
  • Anthony Junior ikenwa
    June 6, 2010 at 7:54 pm
    Hello everyone!
    well i just bought blackMagic extreme 3d, got it installed on my pc, i work so hard to make it work but it doesn’t work it doesn’t capture any image, but i can only hear a sound from the audio out put, input no detection , i suspect it may compatibility problem, can anyone advice me on what to do? My spec is:- Window XP32bit, service pack 3, 3ccc Panasonic broadcast camera old analogue, GT295 nvidia graphic card, 1TB SATA harddrive, motherboard Rampage11, processor core i7, my media express cannot detected my video card. someone help newbie
    thanks
  • Ian Clark
    October 1, 2010 at 7:27 pm
    I am having similar problems with Decklink Studio card. I have so far not got it to capture anything. Pretty sure it’s installed right but will not take .avi .mov. Really driving me nuts.
    I’m on Win 7 with 7gig ram. That should work right?
