Activity Forums VEGAS Pro How to use Color bars?
  • How to use Color bars?
    Posted by Gilles Gagnon on March 26, 2010 at 3:01 pm
    I’ve read many times that videographers should video 30sec of color boars before shooting.
    Can someone explain why that is?
    Gilles
    Gilles Gagnon replied 16 years, 4 months ago 3 Members · 6 Replies
  • John Rofrano
    March 26, 2010 at 8:00 pm
    Colors bars enable you to give the tape to someone else and allows them to calibrate their equipment to match your tape. They serve as a references for what the colors should be coming from your camera.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Gilles Gagnon
    March 26, 2010 at 10:35 pm
    Thanks John,
    So if I get it…. no need to record them if I don’t intend on using the tape with another camera????
    Gilles
  • Kevin Wood
    March 26, 2010 at 11:43 pm
    It’s not another camera that you really need to be concerned with. It’s more for broadcast equipment – deck, monitors, vectorscopes, etc.
    So if you’re dropping off your video for, say, a cable access tv program, then you’ll need them so that they can adjust their playback equipment against known good colors. If it’s a wedding dvd, probably not.
    However, it’s always a good idea to use them to make sure your own equipment is working correctly, and as a color correction reference.
  • Kevin Wood
    March 26, 2010 at 11:47 pm
    Also, here is a brief tutorial that may make it more clear: https://www.videouniversity.com/articles/color-bars-and-how-to-use-em
  • John Rofrano
    March 27, 2010 at 3:37 pm
    Thanks Kevin… that’s exactly what I meant by “equipment”. 😉
    ~jr
  • Gilles Gagnon
    March 28, 2010 at 1:49 pm
    Thanks very much guys for the explanation. It now makes sense to me.
    Gilles
