Activity › Forums › Adobe After Effects › How to use an 8bit effect in 32bit ?
  • How to use an 8bit effect in 32bit ?
    Posted by Bernhard Rieder on January 10, 2010 at 4:27 pm
    Hello,
    I have some effects that seems to work only in 8 and 16bit.
    I would like to work in 32bit –
    is there any way I can get the effects in 32bit done as well ?
    thank you
    Todd Kopriva replied 16 years, 8 months ago 2 Members · 1 Reply
  • Todd Kopriva
    January 11, 2010 at 2:12 am
    Just so that you’re clear on what it means that some effects work in certain color depths:
    The effects that don’t work in 32-bpc can still work on a layer in a 32-bpc project. The effects just don’t preserve the precision and over-range values that it is possible to have in a 32-bpc project. If you were already working in 8-bpc and only switched to 32-bpc to fix certain problems, then this limitation might not be an issue for you. For more information about color depths, see this page: “Color depth and high dynamic range color”
    If you do want to preserve as much of the over-range information in a 32-bpc HDR (high-dynamic-range) image as possible while using a low-dynamic-range effect, you can use the HDR Compander effect.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
