Activity Forums Adobe Photoshop how to upres simple logo?
  • how to upres simple logo?
    Posted by Andy Nitchman on March 6, 2006 at 11:01 pm
    Sorry I know nothing about photoshop…
    I need a take a small res logo (198×193 pixels) and modify it
    so it will look decent full screen on a standard devision…
    (this file logo will be part of Final Cut Pro Project)
    any help you can provide will be greatly appreciated…
    -AnDy (FCP 5 n00b)
    2.0GHz Dual-core G5
    2 GB RAM
    NVIDIA GF 6600 256
    Jim Kanter replied 20 years, 6 months ago 3 Members · 2 Replies
  • Tim Kurkoski
    March 7, 2006 at 12:29 am
    You can do it, but the results you’ll get could be slightly fuzzy (depends on the artwork). Your best bet is to go back to your source and get a larger file. Failing that, here’s the best you can do in Photoshop:
    1. Choose Image > Image Size.
    2. Make sure the Constrain Proportions and Resample Image checkbox is on, and choose Bicubic Smoother from the drop-down.
    3. In the Pixel Dimensions box, enter 440 for the height. (For NTSC. If you’re using PAL, use 480. These values take into account both non-square pixels and the fact you’ll want to leave some room around the edges for the TV-safe margins.)
    4. Click OK.
    Bicubic Smoother is designed to smooth out edges to avoid pixellization. You can try Bicubic Sharper as well, it sharpens edges, and may work better, depending on your artwork.
  • Jim Kanter
    March 7, 2006 at 2:55 pm
    It’s usually better to scale the image size up several times in smaller values than in one big jump. Change the image size units to % and increase in 110-115% percent steps.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
