Activity › Forums › Adobe After Effects › How to update After Effects psd ?
Posted by David Del on September 7, 2006 at 8:05 pmWhen I import a graphic into After Effects, if I update that graphic in Photoshop, will it automatically update the reference in After Effects? I don’t see it happening so I wonder if there is a toggle for this…
Walter Soyka replied 10 years, 11 months ago 7 Members · 7 Replies -
Colin Braley
September 7, 2006 at 8:13 pmI’ve never tried this but I think you can right click on it in the project window and click “reload footage.” I’m not sure though and don’t have AE here to check.
~Cikub -
Jon Walker
September 7, 2006 at 8:20 pmActually if you load a graphic into After Effects and select it in your time line and hit apple+E on a mac and ctrl+E on windows it will open the graphic in the application it was created in and once you change and save it and return to AE it will be automatically updated for you. Be careful though…if it is a jpeg file or some other format than photoshop or illustrator it may open some other program in which case you have to designate on your computer what program opens what file by default. There’s a nifty tutorial on this on the creative cow after effects podcast that was just released actually.
Steve Roberts
September 7, 2006 at 9:18 pmSure, as long as you don’t change the number of layers or the layer names. Otherwise you have to re-import the PSD as a comp and replace each layer manually, or just import the new layers.
Of course, if you wanted to import a flattened PSD (no layers), then just go ahead.
Jason Rouleau
September 7, 2006 at 9:24 pmIf all else fails, do what I do : Close your project and re-open it.
Palak Biswas
October 8, 2015 at 6:52 pmthank you… may be i added few layers thats why i cant see the changes that i made in the psd. so there is no option other than importing new comp…
Walter Soyka
October 8, 2015 at 10:19 pm[Palak Biswas] “o there is no option other than importing new comp…”
You could import the new individual layers and place them in your PSD comp manually.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn]
