Activity Forums Adobe After Effects How to unwrap a sphere?
  • How to unwrap a sphere?
    Posted by Michael Patrick heley on May 30, 2005 at 7:26 pm
    I am trying to do an effect where I am unwrapping a logo and text from a billiard ball in my animation. I’ve tried using both Spherize and CC Spheres, which does a nice job of wrapping the logo around a shere shape, but I can’t figure out how to animate an un wrap from the sphere into the 2D flat ainimation. Any Suggestions?
    (Im using 6.5 pro)
    Patrick
    Graham Quince replied 2 years, 8 months ago 6 Members · 7 Replies
  • 7 Replies
  • Filip Vandueren
    May 31, 2005 at 12:31 am
    Bad news is: You can’t do it with those plugins.
    The closest I think you can get is with a “CC Bulge” Effect, combined with a circular mask.
    Animate the bulge down from 1 to 0 while you interpolate the mask from circle to the full layer.
    Unfortunately. Bulge is not a true Spherize distortion, but it might come close enough for your project.
    (To my taste the Spherize-filter doesn’t actually look like a sphere either, though CC Sphere nails it)
    for a true unwrapping effect, you’ll need a 3d program. I know Cinema 4D can do it easily.
    As for 3rd party plugins:
    I’m not sure if this effect can be accomplished with 3d invigorator.
    But Forge.net’s Freeform might do the trick.
  • Yoondo
    May 31, 2005 at 2:09 am
    Off the top of my head, would optics compensation work on that?
  • Tom Daigon
    May 31, 2005 at 2:15 am
    Check out the Conoa plugins. I believe their true 3D spere will unwrap
  • Filip Vandueren
    May 31, 2005 at 2:37 am
    Indeed it does,
    Conoa’s homepage seems to be offline, but you can get to the details via here:
    https://www.conoa.com/products.html
  • Michael Patrick heley
    May 31, 2005 at 7:22 pm
    Thanks all for the suggestions. The conora plugin seems exatcly what I need, but don’t have the budget for it right now. Ended up using FishEye from Petes Plugins, as a coprimise.
    http://www.petewarden.com
    Patrick
  • Sashank Kondepudi
    December 8, 2023 at 9:53 am
    I know this is a bit late, but I was looking for a solution and I found this plugin. It’s paid ofc, but atleast we have some direct solution now.
  • Graham Quince
    December 11, 2023 at 4:34 pm
    That’s a neat plugin.
