Activity Forums Blackmagic Design Fusion How to unlock a keyframe in the spline editor?
  • How to unlock a keyframe in the spline editor?
    Posted by Smet Kira on November 10, 2024 at 3:25 pm
    Hey, everybody. I still can’t find a solution to the problem on the internet. I using Mocha pro to transfer tracking results to the fusion tracking node. I get a modifier. I want to adjust the value of the keys to correct the inaccuracy of the tracking, but its keys are locked. How do I unlock them?
    Smet Kira replied 1 year, 10 months ago 2 Members · 2 Replies
  • Kelly Griffin
    November 10, 2024 at 5:34 pm
    If I’m understanding you correctly (and I may be wrong, but) I think if you select all your points and do a right-click you should see an option for “modify only” or something, which should then let you move them.
    I think (?)
    Good luck!
    –K
  • Smet Kira
    November 11, 2024 at 1:54 am
    Hi. Unfortunately that didn’t solve the problem. I forgot to write that the keys can be changed by time position (left or right) but not by value (up or down).
