Activity Forums Boris FX How to uninstall Continuum 6 mac
  • How to uninstall Continuum 6 mac
    Posted by Girshon Rutstein on July 10, 2009 at 9:01 pm
    I tried Continuum 6 for AE CS3 on iMac and it messed up my drop down effect menu. I also tried on my mac pro. The same thing. How do I remove plugins. I finally found a them in Library, Application Support, Common folder on my iMac but there is no such a directory on my Mac Pro. Very strange… I love my mac but windows are more organize what regards to plugins.
    Dan Pinard replied 11 years, 2 months ago 6 Members · 6 Replies
  • Girshon Rutstein
    July 10, 2009 at 9:19 pm
    Never mind I have found it!
  • Scott Thomas
    July 21, 2009 at 10:21 pm
    I have the same problem. Not very Mac literate, so how did you find and delete BCC 6. My code is not working and I need to do a clean install.
  • Dan Leno
    August 19, 2009 at 7:48 am
    Hello,
    I installed the trial version of 15 days Boris continuum 6 and I can not get rid. I thought I put everything in the trash since "library / application support" but unfortunately when I run Motion, I still find all the plugins bcc6 viewing. They are inactive and it pollutes my menus. A solution please (No reactivation or how to remove). Thank you
  • Kirsten Lepore
    October 22, 2009 at 5:19 am
    How did you do it?? I have the same problem!
    http://www.kirstenlepore.com
    kirsten.lepore@gmail.com
    (732)673-2337
  • Matt Mullen
    October 23, 2009 at 5:00 pm
    There are a few ways to uninstall.
    If you launch the installer, enter the serial code, and navigate to the custom install screen you will see a pull down at the top. Choose the uninstall option from the pull down and the plug-ins will be uninstalled.
    To manually uninstall navigate to Mac HD> Library> Plug-Ins> FxPlug and remove any BCC files.
    If you have installed from the most recent version of the BCC 6 installer you will have an uninstaller script in MacHD> Applications> BCC6. Run the script and you will uninstall the plugs.
  • Dan Pinard
    June 24, 2015 at 3:17 am
    Thank you. This post saved my butt!
    Tucson Dan
