Activity Forums Avid Media Composer How to turn off auto import of QTs
  • How to turn off auto import of QTs
    Posted by Frederic Lumiere on March 4, 2013 at 10:25 pm
    I turned off all the options in the AMA settings (Auto link to AMA volumes, etc…)
    Somehow, when I plug in a drive with QT on it, MC keeps on trying to import them. Anyway to turn this very annoying feature off?
    John Pale replied 13 years, 6 months ago 3 Members · 4 Replies
  • Michael Phillips
    March 5, 2013 at 2:59 am
    v6.5 brought the capability of turning off auto-moount which is the issue you are seeing and want to turn off.
    Michael
  • Frederic Lumiere
    March 5, 2013 at 3:34 am
    That’s what I turned off somehow it still mounts the drives and opens the same bin over and over…
  • Michael Phillips
    March 5, 2013 at 11:48 am
    Maybe it is because this drive had been mounted before? What happens if you unmount it from the system. I am not in front of an MC right now, but at the bottom of the File menu there is something about mount/unmount. Try removing it and see if it helps with the automount turned off.
    Michael
  • John Pale
    March 5, 2013 at 1:48 pm
    Did you quit MC and relaunch? some of the AMA prefs need that to take,
