Activity › Forums › Adobe Premiere Pro › how to turn multi-cam toggle ON for multiple video tracks in a timeline?
Posted by Alex Dobrenko on February 16, 2018 at 7:02 pmHey all – So I am using multicam but have multicam clips in various video tracks, and I can only see the multi-cam view for the track that is selected. See images below:
Example A: In this one, multi cam works bc the video clip is in track 1
Example B: Multi cam does not work bc clip is in track 2
Blaise Douros replied 8 years, 7 months ago 3 Members · 6 Replies -
Blaise Douros
February 17, 2018 at 12:14 amAs far as I know, you can only use Multicam View in track 1. Maybe there’s a way I’m not familiar with, but I’m pretty sure this is how it works.
Herb Sevush
February 17, 2018 at 3:20 pm[Blaise Douros] “As far as I know, you can only use Multicam View in track 1.”
That is incorrect. Multicam works on the lowest enabled track. If you want it to work on track 2, make sure track 1 is disabled and track 2 is enabled.
By the way this is a terrible design. It requires constant switching of track status and makes it impossible to view continuous multicam if you use multiple tracks. The ideal situation is that the multicam viewer show whatever is on the highest enabled track in use. This is probably the worst flaw of the Ppro multicam paradigm.
Herb Sevush
Zebra Productions
nothin\’ attached to nothin\’
\”Deciding the spine is the process of editing\” F. Bieberkopf -
Alex Dobrenko
February 17, 2018 at 5:28 pmYES! This is my issue. Glad i know its a bug and not something I’m missing. Any idea if they’re going to be fixing it any time soon?
Herb Sevush
February 17, 2018 at 6:49 pmI wish it were merely a bug because that would be fixable. This is a design decision and I don’t think they have any interest in changing it
Herb Sevush
Zebra Productions
Alex Dobrenko
February 17, 2018 at 7:00 pmhttps://www.youtube.com/watch?v=praFGD51ih8
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Blaise Douros
February 21, 2018 at 6:59 pm[Herb Sevush] ” Multicam works on the lowest enabled track. If you want it to work on track 2, make sure track 1 is disabled and track 2 is enabled.”
Huh. I never knew that. Mostly because I don’t understand why anyone would think to design it that way.
