Activity › Forums › Adobe After Effects › How to turn a looped shape in After Effects into a line
  • How to turn a looped shape in After Effects into a line
    Posted by Simon King on June 5, 2023 at 5:21 pm
    I use mapping software which will generate country outlines as a circular looped shape. I need to be able to delete a large portion of the vertices to make it into a single line for part of countries border. When deleting the vertices I cant make them stop looping to the other end of the shape layer. Does anyone know how to “cut” this circle to turn it into just an end to end line?
    Brie Clayton replied 3 years, 3 months ago 3 Members · 3 Replies
  • Walter Soyka
    June 5, 2023 at 8:37 pm
    Yes! You need to switch your shape path from Closed to Open.
    Select the two connected points that you wish to separate, then right-click (or go to the Layer menu), select Mask and Shape Path, and uncheck “Closed.”
  • Simon King
    June 10, 2023 at 10:13 am
    Brilliant, thank you. Been trying to figure that one out for ages.
  • Brie Clayton
    June 11, 2023 at 2:55 am
    Thank you for your solve, Walter!
