Activity › Forums › Apple Final Cut Pro Legacy › how to transfer 3/4″ tapes from Sony VP 7020 Umatic on Final Cut?
Posted by Vihang Walve on January 23, 2012 at 8:51 pmI have this old Sony VP 7020 and My reels on 3/4″ tapes..
does anyone know how can I digitize it in Final Cut Pro???vihang
Chris Tompkins replied 14 years, 8 months ago 3 Members · 4 Replies -
Neil Patience
January 23, 2012 at 9:11 pmUsually you would use kind of capture card there are many options of both internal cards or external boxes from AJA Kona, Blackmagic or Matrox.
Depending on your budget and the Mac you use one of these will be suitable.
However since the 7020 only has a composite video output (I think) then a cheaper option would be something like this:
https://www.amazon.com/Hardware-ADVC-55-d-Converter-Ntsc/dp/B000HGVZG0
which will take analogue video and turn it into a firewire output which you can then easily capture without the need of a more sophisticated card.
best wishes
Neil
http://www.patience.tv -
Vihang Walve
January 23, 2012 at 9:19 pmThanks Neil
I have a AJA lo express but I dont know how exactly that should be attached to the Umatic?vihang
Neil Patience
January 23, 2012 at 10:41 pmI am pretty sure that the i/o Express has not got the option for an analogue composite video input. It only supports SDI in and out and Component/Composite out. (but not in)
So there is no way of using that with your Umatic machine.
You need something that has an analogue composite input. Which you simply attach via a standard BNC cable to the video output of the Umatic.
Obviously you need to connect up the audio as well.There was no RS422 remote option on the Umatic either so you will have to use ‘capture now” as there will not be any deck remote control options.
Probably the Canopus video/firewire box is the cheapest option as long as you are happy with DV res – should be OK for Umatic.
Or you could hire an IO HD which does have composite in and would allow you more flexibilty on your capture codec but that may not prove to be easy or cost effective depending on where you are.
best wishes
Neil
Chris Tompkins
January 23, 2012 at 11:25 pmI have a working AJA IO LA you can buy real cheap that will do the job.
Chris Tompkins
Video Atlanta LLC
