Activity › Forums › Adobe After Effects › How to this over character projection?
Posted by Adrian Chircu on April 8, 2017 at 1:15 pmHi, so I know this is probably 99% done with a real projector, BUT is there a way to replicate this with a green screen and no projector? Just AE?
The effect starts at 1:09
https://www.youtube.com/watch?v=tfrWuiQ4QNc
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Richard Garabedain replied 9 years, 5 months ago 4 Members · 7 Replies -
Adrian Chircu
April 8, 2017 at 5:05 pmIm not interested in the lightning or I think you missed the part which I`m only interested in and that is the projection part of the video at 1:09 time in the video.
The part when another video is played on the guy singing and it gives it a really nice melancholic effect. That`s what I`m interested in. The green screen was just so that it would look closer to his effect since I do not have a projector to project films on me and film it like he does, and instead of the green screen I would put some black/gray background to maybe apply some kind of effect so that it looks like his and then apply the same effect on the rotoscoped version of me so I can distance myself a little from the green screen, like it would happen if I had a projector.
Walter Soyka
April 8, 2017 at 5:17 pmSee Blend modes:
https://helpx.adobe.com/after-effects/using/blending-modes-layer-styles.htmlWalter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Roei Tzoref
April 8, 2017 at 5:22 pmI believe you could replicate this projection, and support Walter’s suggestion of using blend modes.
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials -
Adrian Chircu
April 8, 2017 at 5:27 pmI`ve tried different blend modes, but couldnt come close to his video in terms of realism. It looks like its STUCK to my body, it`s actually more like this video when I use different blend modes.
https://www.youtube.com/watch?v=L-rQZ6IGhCM
The effect that I get with certain blend modes is something like that video which starts at 00:54. It looks stuck to me and really weird. I`m sadly after something more realistic.
If anyone knows a better way or maybe I just didnt chose the right blending mode with the right settings.
Walter Soyka
April 10, 2017 at 7:37 pmYou could use two layers of projection — one for the body only (use your key as an alpha matte) and a separate one for the background. You can then create some separation by offsetting one relative to the other.
If you want to get really fancy, you can distort what’s projected over the body, but it will take time to do this realistically. Some subtle Displacement Map or CC Glass based on a high-contrast version of your keyed character might help a little:
https://helpx.adobe.com/after-effects/using/distort-effects.html#displacement_map_effectWalter Soyka
Richard Garabedain
April 10, 2017 at 8:53 pmCC SPHEREIZE THE COMP..o..and then try it on projection..perhaps use a displacement map of the scene
Richard Garabedain
April 10, 2017 at 8:57 pmoh i got it..create your objects moving around using cc sphere then make that a 3d layer that projects shadows on to a 3d set then use those shadows as a displacement map for your cc sphere…would that work..i think that would work..too bad you cant cast shadows that look like the objects color
