Activity Forums Adobe After Effects How to texture multiple layers efficiently?
  • How to texture multiple layers efficiently?
    Posted by Arne Münch on June 4, 2015 at 3:37 pm
    Hi community
    What is a smart workflow for adding textures in AE?
    For example I have got a plant with lets say 20 leaves, which move independently in the wind.
    In another comp I have made a grungy texture.
    The normal way copying the texture 20 times above that leaves, parent them all to their layer below, switching their mode to “overlay” or what ever and switching the button “preserve transparency” seems for me very inefficient. Now you have got twice as much layers and the new ones in full size of the texture comp.
    I prefer to use the effect “Compound Arithmetic”. With that you can have only one texture layer in the comp which you can switch invisible, and put that effect on all the leaves. (Not working with shape layers, you have to precomp them”
    But you can´t change the section, which the effect uses for the texture, its always the upper left part. So all the leaves get exactly the same section of the texture.
    It would be so much better, if their were an effect like “Compound Arithmetic” with the difference to be possible to decide which section of the texture you want to take for the effect. Is there maybe a plugin or some other effect which can do this?
    Or any other workflows?
    Ideas very welcome..
    Arne Münch replied 11 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
