Activity › Forums › Blackmagic Design › How to tell PCIe from PCIx
Posted by Jay Lee on June 21, 2007 at 3:16 amGood evening,
How can we tell from looking at a BM card (Decklink) whether it is PCIe or PCIx with out opening up a system and attemting to put in in a slot?
There does not seem to be any model# designation or indication on the actual card.Many thanks,
J
Bob Zelin replied 19 years, 3 months ago 3 Members · 5 Replies -
Yves De muyter
June 21, 2007 at 5:36 amLength of the part of the card that fits into the slot. PCIe is something like 1 inch, PCIx is approx 5 times longer.
-Yves
Jay Lee
June 21, 2007 at 5:50 amThank you Yves,
I was under the impression that the physical difference which much more subtle than that?J
Yves De muyter
June 21, 2007 at 7:23 amhttps://en.wikipedia.org/wiki/Image:PCIExpress.jpg
This is an illustration of the different connectors. The bottom one is a “regular” 32-bit PCI slot. A PCIx is not shown, but it is an extension of the 32-bit PCI slot (see https://en.wikipedia.org/wiki/Image:Intelpromtserverpcixadapter1000mta342.jpg for a real 64-bit PCIx connector). Please note that not all Decklink cards feature a full-size PCIx connector, somethimes they’ve shortened it to a regular PCI connector like shown here:
https://nl.wikipedia.org/wiki/Afbeelding:Audigy2zs.jpgThat does not mean it will work correctly in a 32-bit PCI slot though! It will sort-of-work with a lot of black flashes on the decklink output and recording only for a couple of seconds until it stops with far too many framedrops.
-Yves
Jay Lee
June 21, 2007 at 7:30 amThank you Yves,
Are situation is this: We have an existing BM Decklink Pro that is about 1 year old that does not fit in the Mac Pro (thank you apple) so we are looking for a replacment card. There are a couple of used cards available locally but the sellers cannot acertain whether they are PCIx or PCIe.
Our understanding is the one we posses is ‘x’ but mac pro requires ‘e’. The physical difference can not be very different since the card we have now very nearly fits but not quite.Cheers,
J
Bob Zelin
June 21, 2007 at 9:55 pmbring your computer to the reseller, and have them install it for you, and prove to you that it works. This will answer your issue.
PCI-X cards don’t “almost” fit into PCI-E slots (not unless you use a big hammer).Don’t worry, your new PCI-E card will be outdated soon anyway, as everything else you own will. We are all in the same boat. Welcome to the video business.
Bob Zelin
