Activity › Forums › Adobe After Effects › How to take still frames?
  • Topher Welsh
    January 16, 2008 at 6:11 pm
    The way that I do it is you enable time remapping, create a keyframe on the frame you want, delete the first and last time remapping keyframes, shorten your work area to the few frames right there, and export as a jpeg sequence, and then open it in PS and pull the one that you want.
    And then you can save that to whatever format you need outta PS.
    sounds like a long process but its actually pretty fast once you do it a couple of times.
    Topher Welsh
    Head Editor & Motion Graphics
    http://www.scout.com
  • Topher Welsh
    January 16, 2008 at 7:10 pm
    I guess I can stop using my crappy way and start working like the pros. Thanks David. hahaha
    Topher Welsh
