Activity Forums Adobe Premiere Pro How to swap a set of MXF files for a set of quicktime?
  • How to swap a set of MXF files for a set of quicktime?
    Posted by Mark Francombe on February 10, 2018 at 10:42 pm
    Maybe the whole question is in the subject?
    I have edited a few projects using MXF files direct from the camera, it worked but on my computer, was sluggish and difficult. AFter some tiesting, I discovered that converting stuff to quicktime prores worked a treat.
    Some project have become worse over time, and multiple crashes.
    now After my discovery, Id like to try to replace ALL the footage in the project with a newly encoded set of quicktimes…
    I can right click on a single clip and select Replace footage, choose the quicktime version, but if I select the whole bin, or multiple files, the option isnt there.
    All the files have exactly the same name apart from the extensions. So A010C341_1802060T_CANON.MXF has become A010C341_1802060T_CANON.mov
    How can I achieve this?
    Mark Francombe
    Boss Creative
    Transform
    Mark Francombe replied 8 years, 7 months ago 3 Members · 3 Replies
  • Eric Santiago
    February 10, 2018 at 11:22 pm
    I had to trick files into switching a few years ago.
    I used Resolve to achieve this.
    Hope you find a way in PPro.
  • John Pale
    February 10, 2018 at 11:23 pm
    Select the clips. Make Offline.
    Then Link Media to the new Quicktimes.
    If your new Quicktimes have a different audio configuration than the original media, you might have an issue…but other than that, its pretty simple.
  • Mark Francombe
    February 11, 2018 at 8:04 pm
    Thanks, it was the “Make offline” clue that worked…
    Mark Francombe
    Boss Creative
    Transform
