Activity Forums Adobe After Effects Expressions How to stop the camera and move the world
  • How to stop the camera and move the world
    Posted by Mike Gottschalk on January 28, 2016 at 11:21 pm
    hi—
    I had posted a couple days ago in “After Effects”, but this is probably a more expression-intensive issue appropriate for this forum.
    I have some live footage taken from a moving car looking ahead down the road. I have performed Track Camera in After Effects and have created a 3D Tracker Cam, adding a few solids into the scene. The track looks good.
    My issue is this:
    I’d like to create a duplicate composition which is visually identical, but has a stationary camera. The solids within this comp would be the only moving objects.
    I believe I can use an expression on a null which inherits the inverse of my original camera’s position, and then parent my solids to that, but when I try to handle the orientation issues I begin to get lost.
    Does this sound like the right approach for this issue? And is there a straightforward solution that I may have overlooked?
    Thanks so much for any ideas.
    Mike
    Mike Gottschalk replied 10 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
