Activity › Forums › Apple Final Cut Pro Legacy › How to stop colour banding in vignettes?
  • How to stop colour banding in vignettes?
    Posted by Michael Lansdell on September 20, 2010 at 9:17 am
    Hi, I like to put a very slight vignette on programmes when I’m doing the final grade and graphics etc. I used to use a pre-made vignette knocked up in Photoshop but now I use a colour matte with a mask shape cut out so I can adjust it easily for different shots if I want to. I used the ‘Soft Light’ transfer mode for both of these as I like the subtler effect it has to some other transfer modes, and I use it at varying opacity, but mostly between 36-46% I also grade in ‘Uncompressed 8 bit 4:2:2’, and for SD PAL broadcast.
    My problem is, I get weird colour-banding sometimes, mostly noticeable over mid darkness areas of flatish colour. Is there something I can do to prevent that?
    Many thanks,
    Michael Lansdell
    Online/Offline Editor
    My system:
    2 x 3 GHz Quad-Core Intel Xeon
    5GB DDR2 RAM
    512MB ATI Radeon X1900 XT
    OS X 10.4.11
    Final Cut Pro 6.0.4
    After Effects CS4
    Blackmagic Design DeckLink HD Extreme (6.6.2)
    Take a gander at my personal blog:
    http://www.monstersareart.co.uk
    Stephen Smith replied 16 years ago 6 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    September 20, 2010 at 9:39 am
    Hi Michael,
    The banding is a problem associated with the 8b.
    You may try add a bit of noise to the vignette, or render in 10b.
    If you render in 10b you can add a bit of blur to your Photoshop file (8b RGB).
    Rafael
    http://www.nagavideo.com
  • Bouke Vahl
    September 20, 2010 at 10:29 am
    Rafael is right, BUT:
    10 bit does do the trick, but is not the solution, as your work probably ends up in 8 bit anyways…
    (Broadcast is most of the time 8 bits nowadays…)
    Experiment with noise….
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Stephen Smith
    September 20, 2010 at 2:39 pm
    Take a look at: Effects, Video Filters, Image Control, Reduce Banding.
    Best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Mark Suszko
    September 20, 2010 at 3:07 pm
    Question: is his photoshop file of the vignette the wrong resolution, and could this be causing banding when it is scaled too much?
  • Mark Maness
    September 20, 2010 at 4:30 pm
    You get this same banding when using the vignette plug also. Whether the plugin be from Apple, Noise Industries, Tiffen or anyone, you’ll see this banding. Yes, 10-bit rendering does make it look good but Stephen is right, most all broadcast facilities are airing in 8-bit, so the banding comes back on broadcast.
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Bouke Vahl
    September 20, 2010 at 4:33 pm
    Hello Dave!
    You are my wife now, Dave!
  • Stephen Smith
    September 20, 2010 at 4:37 pm
    Bouke,
    I don’t get it?
    Stephen Smith
