Activity Forums Maxon Cinema 4D how to stick texture on objects even after cloner is made editable
  • Peter Cavallero
    October 1, 2013 at 6:37 pm
    Hey Manny,
    Exact same issue here… Did you ever find a solution to this?
  • Brian Jones
    October 1, 2013 at 11:42 pm
    probably you just need to use Fix Texture in the Cloner/Object tab
  • Peter Cavallero
    October 2, 2013 at 5:07 pm
    Guess I should have been clearer- My issue is how to preserve an effector’s animation after making a cloner object editable. I’m still pretty new to C4D- hope the answer is not too obvious…
  • Brian Jones
    October 2, 2013 at 10:19 pm
    if the Fix Texture switch in the Cloner works you won’t have to make the cloner editable at all and the animation is preserved. Does it work that way? Otherwise you’d have to export the cloner to alembic and bring it back it (unless someone knows something better)
  • Peter Cavallero
    October 3, 2013 at 1:31 pm
    Awesome! The fix textures switch worked. Took me a minute to get it. Thanks Brian.
  • Margherita Ballarin
    November 19, 2014 at 10:27 pm
    hello! same problem here…
    how exactly did you make the fix texture switch work?
    cause it doesn’t make any difference here!
    many thanks,
  • Brian Jones
    November 20, 2014 at 3:48 am
    From the Help – This method works with every projection type, except for UVW, camera and frontal mapping. So your material meeds to be something other than UVW (probably).
