Activity Forums Adobe After Effects Expressions How to start animation at last letter with Amortype 2.0 ??
  • How to start animation at last letter with Amortype 2.0 ??
    Posted by Guido Giardino on February 16, 2017 at 2:36 pm
    Is there a way to start the animation from the last letter?? Invert the sequence of the letters order like the “Shape: Ramp up/down” of the range selector does?
    My problem is that when I only set the position X in the preset, the animation is different when the position X has a positive number than when is negative.
    Please help!
    Many thanks!
    freq = effect("Frequency")("ADBE Slider Control-0001");
    decay = effect("Decay")("ADBE Slider Control-0001");
    if(effect("Random Time")("ADBE Checkbox Control-0001")==0){
    retard = textIndex*thisComp.frameDuration*effect("Offset")("ADBE Slider Control-0001");
    }else{
    seedRandom(index*textIndex,timeless=true);
    retard = random(0,1);}
    t = time - (inPoint + retard);
    startVal = [100,100,100];
    endVal = [0,0,0];
    duration = effect("Duration")("ADBE Slider Control-0001");
    if (t < duration){
    linear(t,0,duration,startVal,endVal);
    }else{
    amp = (endVal - startVal)/duration;
    w = freq*Math.PI*2;
    endVal + amp*(Math.sin((t-duration)*w)/Math.exp(decay*(t-duration))/w);
    Ilya Sire replied 7 years, 7 months ago 3 Members · 3 Replies
  • Dan Ebberts
    February 16, 2017 at 5:39 pm
    I think you could add a new variable, like this at the top of the expression:
    idx = textTotal – textIndex + 1;
    and then replace textIndex with idx in the rest of your expression.
    Dan
  • Guido Giardino
    February 16, 2017 at 8:15 pm
    HI! If somebody needs the answer for this post, Dan Ebberts solve the issue!! I want him to be my best friend forever!
    By accident I click on “report post” and his answer gone away!
    Many thanks, Dan! Amazing!!
    idx = textTotal - textIndex + 1
    retard = idx*thisComp.frameDuration*effect("Offset")("ADBE Slider Control-0001");
    }else{
    seedRandom(index*idx,timeless=true);
    endVal = [0,0,0];
    if (t < duration){
    }else{
    w = freq*Math.PI*2;
  • Ilya Sire
    February 3, 2019 at 1:52 pm
    Thank you for this question and solution,
    i just found this post which is start from left or random,
    How can i start it from the center?
