Activity › Forums › Adobe After Effects › How to stabilize an unsteady Steadicam
Posted by Fred Matthews on January 17, 2006 at 7:35 pmI have a fifteen second shot that is a bit shakier than I want. You can see the steps of the photographer. WHat is my best option for fixing this shot. It is a slow walk into a small room that pans right and lands on a sitting area. The shot is full wide shot with a wide angle lens.
Superstar replied 20 years, 7 months ago 4 Members · 6 Replies -
Steve Roberts
January 17, 2006 at 8:21 pmIn my opinion, you need to do it by hand, because there is no static point in the shot to track.
However, as a guide … you might be able to track certain points, apply that tracked motion to a solid, then copy that path into a mask and apply render>stroke to create a stroked path of each of the points. Next, you could remove mask points and smooth that path to create a guide representing the ideal, smooth path. You’d use this guide as you manually adjust the footage position and/or anchor point to attempt to steady it.
I’ve never tried it. 🙂
Steve
Fred Matthews
January 17, 2006 at 8:37 pmHere is what I am currently doing.
I have added the 3D layer to the clip and frame by frame I have adjusted the Z Rotation acording to a vertical line that I placed on the clip that I compare to the center most vertical line in my clip. It workes okay but is very time consuming and I have been at it all day.
If I don’t like the results from this I will attempt what you suggested.
Any other thoughts?
Steve Roberts
January 17, 2006 at 8:50 pm[Fred Matthews] “Any other thoughts?”
Sorry, not really. It’s easier to smooth something when you have a guide for comparision.
Steve
Marc Bauwens
January 17, 2006 at 10:52 pmTry a plugin called Steadymove Pro from a company called 2D3.
It’s quite nice and might yield the results you’re looking after. -
Fred Matthews
January 18, 2006 at 10:43 pmMy initial attempt has proven to be okay at best but with the time crunch will have to do. I will look into that product for the future. We don’t call upon the use of a Steadicam very often.
Superstar
January 19, 2006 at 1:17 amI’ve used a plug-in from The Foundry called Steadiness and it worked a treat on a similair type of shot to yours. I think you can download this or get it from The Foundry to evaluate.
The nice thing about the plug-in is that you don’t have to place tracking markers in the scene. It saved a couple of major jobs I worked on a while ago.
Best of luck with the shot!
