Activity › Forums › VEGAS Pro › how to stabilize a part of a clip
  • how to stabilize a part of a clip
    Posted by Kyle Le on July 24, 2016 at 4:45 am
    how do i stabilize a part of a clip from a longer clip without the whole thing stabilized
    Wayne Waag replied 10 years, 2 months ago 7 Members · 9 Replies
  • 9 Replies
  • Graham Bernard
    July 24, 2016 at 6:58 am
    Split off the wobbly piece and use Stabilize. Is there something further we should know?
    * Grazie
  • Kyle Le
    July 24, 2016 at 8:43 am
    there are some parts of the clip that i dont want stabilized. but when i split it or do remove from it still stabializes the whole thing
  • Graham Bernard
    July 24, 2016 at 9:42 am
    Are using the SONY Stabilize Fx?
    * Grazie
  • Aleksey Tarasov
    Split off the wobbly piece, make subclip, and use Stabilize…
  • Eric Clinch
    July 24, 2016 at 9:43 am
    You could try making a copy of the clip with a different name. Stabilise the original but not the copy. Split each and use parts from each.
  • Graham Bernard
    July 24, 2016 at 9:51 am
    Now I’ve done the heavy lifting, do what the others said. I’m done here.
    * Grazie
  • Paul Berk
    July 24, 2016 at 5:25 pm
    Create a subclip. Stabilize that.
  • George Dean
    July 24, 2016 at 6:11 pm
    Hi Kyle,
    The easiest way is most likely as Paul suggest, make your splits, then create a sub-clip of the part you want to stabilize, stabilize it, then delete the original part you split and replace it with the sub-clip.
    I’m sure you realize when you apply stabilization the end result will be zoomed in compared to the original. Depending on where you make your splits (cuts) and how much stabilization you apply, the jump from the non-stabilized section to the stabilized section and back again, may be quite jarring. Best to find a scene change to make the splits on.
    Best Regards…….George
  • Wayne Waag
    July 24, 2016 at 10:14 pm
    The only problem with such a simplistic approach is that your stabilized clip with most likely be zoomed in a bit or a lot, depending upon its motion. The result will likely be an immediate “zoom in” and “zoom out” at the subclips borders. The newest version of the Mercalli stabilizer enables a gradual transition in and out. Likewise, the venerable Deshaker script always leaves the first and end frames intact so that the transitions will always be smooth. For that reason, it’s best to stabilize at the “natural” start and end of an event, rather than simply created a subclip. However, I’d certainly give it a try, since it’s certainly easier than either use of Mercalli or Deshaker.
    wwaag
