Activity › Forums › Apple Final Cut Pro › How to split stereo audio pair in FCP X
  • How to split stereo audio pair in FCP X
    Posted by Keith Betts on June 20, 2013 at 9:50 pm
    I’ve done this operation for years in FCP 6 but haven’t figured out if it’s possible in FCP X. I recorded 2 channels of audio at a dance recital. 1 channel is directly from the audio console and contains pristine audio of music and announcements. The second channel is mounted on the camcorder as back-up and to record audience applause which would normally not be recorded from channel 1. Now in FCP 6 I would go to Modify – Stereo Pair and deselect it thus creating 2 mono and independent channels I could then adjust accordingly. I can eliminate the slight delay of the 2 channels in stereo and lower the camcorder mic to just provide audience applause. Any ideas if this is possible in FCP X? Any direction on how I can accomplish this?
    Keith Betts replied 13 years, 2 months ago 3 Members · 3 Replies
  • T. Payton
    June 20, 2013 at 10:07 pm
    You want to use audio component editing in FCP X.
    Take a look a the user guide here:
    https://help.apple.com/finalcutpro/mac/10.0.6/#verdcd1cc1
    T. Payton
    OneCreative, Albuquerque
  • Nikolas Bäurle
    June 20, 2013 at 11:49 pm
    The easiest way is to simply open the inspector, go to Audio, click on the green track and change it from stereo to dual mono, then you should see two seperate tracks, click the one off you don’t need. The Audio Komponent Method is better if you need to see the tracks in the timeline, can be very helpful. Personally I prefer the inspector method.
    “Always look on the bright side of life” – Monty Python
  • Keith Betts
    June 21, 2013 at 1:50 am
    Thanks. I figured out to go to Channel Configuration and did like you stated, change audio from stereo to dual mono. I then used Clip – Expand Audio Component to access my two channels of audio and adjusted volume of my on camera mic to eliminate the delay yet maintain audience applause. Quite proud of myself as I transition from FCP 6 to X. Though I know it won’t always be this easy!
