Activity › Forums › Adobe Premiere Pro › How to speed up export/render times on premiere CC?
Posted by Alexis Drakopoulos on April 21, 2015 at 2:34 pmLaptop specs:
I7 4980HQ
32GB DDR3L
512GB M.2 1200mb write/read
1TB SSD 550mb write/read
GTX 980M GPUFiles:
1080p60fps
Format h.264 at Source Quality High Bitrate.What tips do you guys have on increasing the quality/reducing render time? I see it’s using 100% CPU but only 30% Ram at around 8gb ram at a time.
Tero Ahlfors replied 11 years, 5 months ago 5 Members · 11 Replies -
Jeff Pulera
April 21, 2015 at 4:17 pmCan you please post a screen shot of the Export Settings for review? Checkboxes for “Max Render” and “Max Bit Depth” can add to render times, but are not needed much of the time. Could that be an issue for you?
Thank you
Jeff Pulera
Safe Harbor Computers -
Alexis Drakopoulos
April 21, 2015 at 9:33 pm -
Jeff Pulera
April 22, 2015 at 1:17 pmDon’t export to C: (system) drive, rather export to a dedicated fast media drive. Also, what does the rest of the export panel look like? There are checkboxes that can increase render times
Jeff Pulera
Alexis Drakopoulos
April 22, 2015 at 3:54 pmis 550mb/s fast SSD fast? it’s 1TB 850 EVO SSD
I should export to D drive? and everything is unchecked I haven’t touched anything, what can I do?
Tero Ahlfors
April 22, 2015 at 4:34 pmWhat are your export times? How long videos are you exporting? What kind of times are you expecting for the exports?
Alexis Drakopoulos
April 22, 2015 at 5:21 pmA 20min video barely edited took me 20min to export, I am exporting a short 4min video now and it only took 5mins to export which is good.
I want to cut it down to around half though. Because I need to be able to export a lot of 20 – 40min videos.
It’s basically just me syncing audio with video and adding a new audio track and then an outro and intro. Shouldn’t take 20mins
Tero Ahlfors
April 22, 2015 at 6:32 pmI don’t know what your source footage is but those times sound fair for high framerate/bitrate H264 encoding.
R neil Haugen
April 22, 2015 at 7:27 pmBreaking up the reads & writes is always good in PrPro. Exporting is nearly totally a reading process, and reading media files is pretty much a one-way read process. So both of those can often (up through 1080) go via a USB3 connection where say, using that for project files or such would slow you to a crawl.
But … that would be one USB3 connection for exporting, and a different one for media you are working from.
Exporting to even a fast flashdrive like some of the PNY 128Gb ones connected through a USB3 port would give you better processing times than sending the export back to a disc that’s getting heavily used for in/out work like your system drive.
Neil
Tero Ahlfors
April 23, 2015 at 3:59 am[Brian De Herrera-Schnering] “Set up Media Encoder to use GPU. Done.”
If he’s not doing anything that would use the GPU that doesn’t really help.
