Activity › Forums › Adobe Illustrator › How to solve my problem which I faced in adobe illustrator 21.1.0
  • How to solve my problem which I faced in adobe illustrator 21.1.0
    Posted by Ingrid Kline on March 15, 2018 at 8:15 pm
    I the long time worked on the project in illustrator. But recently I just did not believe the eyes. This file does not open now. I tried to otkrit the file via other PC, but the program all the same gives to me an error message: Cannot open the illustration. The illustration contains an illegal operand. I hope that there are people who will be able to help me, or the one to whom such error met.
    Elliot Burton replied 8 years, 6 months ago 2 Members · 1 Reply
  • Elliot Burton
    March 16, 2018 at 1:46 pm
    https://helpx.adobe.com/illustrator/kb/troubleshoot-damaged-illustrator-files.html
    Place the damaged Illustrator file in repair illustrator file.
    Important: This solution doesn’t work if you didn’t select Create Compatible PDF File in the Illustrator Native Format Options dialog box when you saved the original file. On the Macintosh platform, the damaged Illustrator file may appear dimmed in the Place dialog box, but you will still be able to select it and place it in the new Illustrator file.
    1. In Illustrator, choose File > New.
    2. Select the appropriate size and color mode, and then click OK.
    3. Choose File > Place.
    4. In the Place dialog box, choose All Formats from the Files of Type pop-up menu (Windows) or choose All Documents from the Show pop-up menu (Mac OS), choose the damaged file, and then click Place.
    5. Name and save the file.
