Activity › Forums › Cinematography › how to soften hd video
Posted by Noor Hussain on October 28, 2010 at 5:39 pmi have a canon 7d.i need to know how can i soften the overall video.hd is a bit crisp n too sharp
Noor Hussain replied 15 years, 11 months ago 3 Members · 6 Replies -
Noor Hussain
October 29, 2010 at 10:37 amIT WOULD BE GREAT if you can breakdown different procedures.You know how the result of film is a little softer than video.
some say you have to decrease the contour correction .some in built feature of video cameras to sharpen the image.hd video is quite hard in a way. -
Richard Cooper
October 29, 2010 at 8:42 pmOn the 7D, try dialing down your “sharpness” setting all the way to the left, same with your “contrast”. Then dial down your “saturation” by 2 clicks from center. This will give you a nice color gradable image and will reduce that “sharp look” you are referring to.
Hope this helps.
Richard Cooper
FrostLine Productions, LLC
Anchorage, Alaska
http://www.frostlineproductions.com -
Noor Hussain
October 30, 2010 at 4:31 amthankyou so much sir
Should i use soft focus as well or not? -
Richard Cooper
October 31, 2010 at 11:44 pm“Should i use soft focus as well or not?”
Not unless you need it for a specific look… and NEVER do this in camera…. Unless you are absolutely SURE you want it that way… save it for post if you really want that specific look.
Richard Cooper
Anchorage, Alaska
