Activity Forums Maxon Cinema 4D How to smooth out vectorizor?
  • How to smooth out vectorizor?
    Posted by Hilary Tsai on May 8, 2021 at 11:02 pm
    I notice that even with the starkest black and white and the clearest image, the vectorizer always makes a squiggly path. I set the tolerance down to 0 and it’s still very jagged–this is something I’ve noticed in general, not with one particular vector image. Are there any tips for getting a completely smooth outline from the vectorizer?
    Hilary Tsai replied 5 years, 3 months ago 3 Members · 4 Replies
  • Jim Scott
    May 9, 2021 at 12:44 am
    I think the problem is that since pixel-based images by their very nature do not have completely smooth transitions between contrasting elements, the Vectorizer will never be able to produce completely smooth paths from them. You can get better results from larger images, and try different “Intermediate Points” and “Angle” settings, but it’s never going to be as good as using extruded vector files. Decreasing the tolerance value actually increases the jaggies by increasing the detail. While increasing tolerance does smooth the paths it will never be able to turn a jagged circle into a smooth one for example, like the paths from a vector would be.
    From the help:
  • Justin Thomson
    May 10, 2021 at 4:33 pm
    Are you exporting images out of Illustrator?
  • Hilary Tsai
    May 21, 2021 at 11:53 pm
    @Justin No, aftereffects. I realize from reading these responses that it was caused by pixel images and will try exporting a vector from illustrator. Makes perfect sense. Thanks, all!
  • Hilary Tsai
    May 21, 2021 at 11:54 pm
    I will try using a vector exported from illustrator. Thank you!
