Activity Forums Maxon Cinema 4D How to smooth out hard edges to blend two objects into one?
  • How to smooth out hard edges to blend two objects into one?
    Posted by Lucas Schwartz on March 6, 2019 at 12:18 pm
    Hi Everyone,
    I would like to smooth out the hard edge marked on the picture to create the illusion of one object. I would like to make the front element of the object “growing out” of the S in the middle rather then having the feel of being attached.
    Picture 1:
    Picture 2:
    I am new to modelling so please forgive me for the probably trivial question. I tried to find tutorials that would be relevant to what I am trying to create but I have had no luck finding one so far.
    Thank you all in advance.
    Best regards,
    Lucas
    Lucas Schwartz replied 7 years, 5 months ago 2 Members · 3 Replies
  • Brian Jones
    March 6, 2019 at 7:36 pm
    the bevel tool on that selected edge in the 2nd example pic looks like it would do the trick *but* the parts of your S would need to be joined to make one object and it would need to be truly attached (run an Optimize)
    13183_softedges.c4d.zip
  • Lucas Schwartz
    March 6, 2019 at 9:28 pm
    Thank you for providing the perfect answer and the great example files. It really helped me to understand what I need to do to achieve my goal.
    Should someone stumble across my question here at a later time I also found this tutorial relevant and interesting: https://www.youtube.com/watch?v=YmUi22qZdkA
    Kind regards,
    Lucas
  • Lucas Schwartz
    March 7, 2019 at 2:31 pm
    Also don’t forget to turn off the “use edge breaks” check box if you are using a subdivision surface.
    See picture below:
