Activity Forums Adobe After Effects How to slow motion…?
  • How to slow motion…?
    Posted by Virgilio Troncoso on June 6, 2005 at 1:19 am
    Hi!I’d like know how to do slow motion in after effects 6.5?
    I did something in wild fx pro, like wrote name and apply a effects call typewrite,import file to after effects, but i’d like know how i can control the velocity or apply slow motion? I holpe you understand my english, and thank you for the help.
    Aharon Rabinowitz replied 21 years, 3 months ago 4 Members · 5 Replies
  • John Dickinson
    June 6, 2005 at 2:45 am
    A good place to start is to check out Time Stretch and Time Remapping in the Help files.
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Sahaba
    June 6, 2005 at 4:45 am
    I believe time remapping. Enable time remapping from the Layer menu..
    Again see that tutorial
  • Aharon Rabinowitz
    June 6, 2005 at 2:21 pm
    It’s important to note that if you don’t have your footage at a high frame rate, when you slow your footage down, it’s going to play a bit choppy.
    When I plan on doing slowmo, I like to render things out of my 3D program at 240 FPS, or to slow every thing down in my 3D program to 1/8 the normal speed.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Sahaba
    June 6, 2005 at 5:17 pm
    Couldn’t you use frame blending to do a fairly good job??
  • Aharon Rabinowitz
    June 6, 2005 at 5:21 pm
    “Fairly” is about right – It’s passable, but not really good. In this case, since none of the elements are real, and you have total control over them, why not plan ahead?
    Also, If you really want to play with slow motion, check out Twixtor from Revision FX – https://www.revisionfx.com – by far the best plug-in for playing with time.
    I think we have a revision FX forum here as well. They can help you use the plug-ins if you run into trouble.
    Aharon Rabinowitz
